Скрипты для сдвига и перемещения слоев по таймлайну
Дефекты при переносе слоев из Adobe illustrator в After Effects
Acid144 » 17 фев 2021, 05:46 » в форуме Adobe After Effects - 1
- 2515
17 фев 2021, 12:31
На мой взгляд Rift самый навороченый - куча функций! Одна проблема - интерфейс. Обязательно смотреть тутор на странице aescript.com.
Layer Random Shifter
http://aescripts.com/layer-random-shifter/
Randomly shifts the selected layers in time within user defined range.
SequenceLayers
http://aescripts.com/sequencelayers/
Sequences the selected layers from the current composition time, by offsetting their inpoint.
pt_ShiftLayers
http://aescripts.com/pt_shiftlayers/
Shifts or staggers selected layers in time by a user defined number of frames or seconds.
rd: Scooter
http://aescripts.com/rd-scooter/
Displays a palette with controls for slipping and sliding various layer settings, such as layer footage source, in/out range, markers, and keyframes. You can use different combinations of these settings for more powerful control over layer editing operations.
Trim to Layer Above and Trim to Layer Below
http://aescripts.com/trim-to-layer-abov ... yer-below/
Trim to Layer Above will trim the layers that are selected to be the same length as the layer above it. Trim to Layer Below, well, trims the layer below the selected layer.
Trim Comp to Contents
http://aescripts.com/trim-to-comp-contents/
Trim or extend comp duration to fit layer contents.
SequenceLayers
pt_ShiftLayers
rd: Scooter
Rift
Rift
http://aescripts.com/rift/
This script provides methods to shift, sequence, stagger, or randomize layers properties like in and out points, keyframes, markers and more, presented in a compact UI.
Elastic Comp Changer
http://aescripts.com/elastic-comp-changer/
Вот еще одна забавная штучка для удлинения или уменьшения длительности в конкретных местах композиции.
Elastic Comp Changer will change the duration of your composition, its layers and its nested pre-comps with the option to offset keyframes as well.
Lazy - Layer Easer
Lazy - Layer Easer
https://aescripts.com/lazy-layer-easer/
Сдвигает слои или ключи анимации по таймлайну в зависимости от установленной кривой.
Lazy allows you to distribute your layers or keyframes along a bezier curve across your After Effects timeline.
- Не Нуб
Transition Shifter
Transition Shifter
https://misterhorse.tv/animation-composer
https://vimeo.com/178183467
Бесплатный скрипт Transition Shifter, который устанавливается в комплекте с бесплатным набором Animation Composer. Работает как с маркерами анимации самого плагина, так и со слоями в целом. Удобство плагина может кому-то понравится, сам лично пока пользуюсь простым pt_ShiftLayers.
примеры использования
Staircase
Staircase
https://aescripts.com/staircase/
Сдвигает слои ступеньками или случайно, а в отличие от других скриптов может группировать по цвету слоев или по количеству.
Staircase is a tool for After Effects that allows you to quickly stagger, sequence and randomise blocks of layers.
foxRetimer
foxRetimer
https://aescripts.com/foxretimer/
Позволяет двигать слои и ключи в композиции, изменяя кривую Time Remapping.
FoxRetimer utilizes AE’s build in time remapping feature instead of manually move layers, adjust keyframes & retime nested comps.
Вернуться в «Каталог скриптов»
