Скрипты для сдвига и перемещения слоев по таймлайну
Описание скриптов на русском и попытка разложить их по функциональным разделам отдельно
Благодарил (а): 11 раз
Сообщение aeplug » 31 авг 2016 02:27
На мой взгляд Rift самый навороченый - куча функций! Одна проблема - интерфейс. Обязательно смотреть тутор на странице aescript.com.
Сообщение aeplug » 31 авг 2016 02:29
Layer Random Shifter
http://aescripts.com/layer-random-shifter/
Randomly shifts the selected layers in time within user defined range.
SequenceLayers
http://aescripts.com/sequencelayers/
Sequences the selected layers from the current composition time, by offsetting their inpoint.
pt_ShiftLayers
http://aescripts.com/pt_shiftlayers/
Shifts or staggers selected layers in time by a user defined number of frames or seconds.
rd: Scooter
http://aescripts.com/rd-scooter/
Displays a palette with controls for slipping and sliding various layer settings, such as layer footage source, in/out range, markers, and keyframes. You can use different combinations of these settings for more powerful control over layer editing operations.
Trim to Layer Above and Trim to Layer Below
http://aescripts.com/trim-to-layer-abov ... yer-below/
Trim to Layer Above will trim the layers that are selected to be the same length as the layer above it. Trim to Layer Below, well, trims the layer below the selected layer.
Trim Comp to Contents
http://aescripts.com/trim-to-comp-contents/
Trim or extend comp duration to fit layer contents.
Rift
Сообщение aeplug » 15 сен 2016 02:01
Rift
http://aescripts.com/rift/
This script provides methods to shift, sequence, stagger, or randomize layers properties like in and out points, keyframes, markers and more, presented in a compact UI.
Elastic Comp Changer
Сообщение aeplug » 07 ноя 2016 16:50
http://aescripts.com/elastic-comp-changer/
Вот еще одна забавная штучка для удлинения или уменьшения длительности в конкретных местах композиции.
Elastic Comp Changer will change the duration of your composition, its layers and its nested pre-comps with the option to offset keyframes as well.
Lazy - Layer Easer
Сообщение aeplug » 19 ноя 2017 11:59
Lazy - Layer Easer
https://aescripts.com/lazy-layer-easer/
Сдвигает слои или ключи анимации по таймлайну в зависимости от установленной кривой.
Lazy allows you to distribute your layers or keyframes along a bezier curve across your After Effects timeline.
psihoepate
Благодарил (а): 3 раза
Transition Shifter
Сообщение psihoepate » 27 мар 2018 16:58
Transition Shifter
https://misterhorse.tv/animation-composer
https://vimeo.com/178183467
Бесплатный скрипт Transition Shifter, который устанавливается в комплекте с бесплатным набором Animation Composer. Работает как с маркерами анимации самого плагина, так и со слоями в целом. Удобство плагина может кому-то понравится, сам лично пока пользуюсь простым pt_ShiftLayers.
примеры использования
Staircase
Сообщение aeplug » 03 июл 2018 10:03
Staircase
https://aescripts.com/staircase/
Сдвигает слои ступеньками или случайно, а в отличие от других скриптов может группировать по цвету слоев или по количеству.
Staircase is a tool for After Effects that allows you to quickly stagger, sequence and randomise blocks of layers.
foxRetimer
Сообщение aeplug » 03 июл 2018 10:05
foxRetimer
https://aescripts.com/foxretimer/
Позволяет двигать слои и ключи в композиции, изменяя кривую Time Remapping.
FoxRetimer utilizes AE’s build in time remapping feature instead of manually move layers, adjust keyframes & retime nested comps.
Вернуться в «Каталог скриптов»
