Скрипты для создания копий и дубликатов
Автор темы - Санта
-резерв-
Автор темы - Санта
Duplicate with Connections
http://aescripts.com/duplicate-with-connections/
Make a copy of a layer and link all its properties to the original using expressions.
DuplicateLayers-n-UpdateExpressions
http://aescripts.com/duplicatelayers-n- ... pressions/
Duplicates the selected layers and if any of the layers have expressions referencing any of the layers being duplicated it will update the expressions to point to the newly duplicated layers. Might make more sense if you watch the demo
True Comp Duplicator
http://aescripts.com/true-comp-duplicator/
Creates a complete duplicate of selected comp hierarchies including subcomps with many options.
ft-Effect Instance
http://aescripts.com/ft-effect-instance/
Create an instance of an effect with one click. Behind the scenes the script makes a copy of the effect and links it with expressions in a way that allows the instance to be anywhere including a different comp.
ft-Effect Instance
Автор темы - Санта
Array
Array
http://aescripts.com/array/
Array makes things much easier for you when you need to duplicate layers a lot of times or change the basic properties of selected layers.
