Скрипты для вспоготалеьного рендера/outputs
Автор темы - Санта
-резерв-
Автор темы - Санта
exportForClient
http://aescripts.com/exportforclient/
Export all text layers in a composition to a .txt file and selected frames as image files. Ready for review. Quick and easy.
pt_ContactSheet
http://aescripts.com/pt_contactsheet/
Use this script to create contact sheets or storyboards out of selected frames from a precomp or footage layer.
Sheetah - Spritesheet Tools
http://aescripts.com/sheetah-spritesheet-tools/
Sheetah turns your After Effects composition into a single spritesheet file blazingly fast. It also features tools to generate custom animation sequences for your spritesheet.
pt_ContactSheet
Автор темы - Санта
Render Frame at Markers
http://aescripts.com/render-frame-at-markers/
Will send to the render queue any frames that are marked by layer markers that are within the comp work area. This would be equivalent to going to a point in time in your comp and selecting "Save Frame As->File".
