Скрипты для размещения слоев в пространстве
Автор темы - Санта
-резерв-
Автор темы - Санта
DistributeLayers
DistributeLayers
http://aescripts.com/distributelayers/
This script allows you to distribute the selected layers in 3D space. In addition to offset position, you can offset rotation/scale/opacity and adds some randomness. The "Factor" parameter allows non-linear offset between layers.
Автор темы - Санта
Layers2Grid
Layers2Grid
http://aescripts.com/layers2grid/
Arranges Selected Layers in a Grid with a choice to arrange them by Rows first (Left to Right) or by Columns first (Top to Bottom).
Автор темы - Санта
Path Duplicator
Path Duplicator
http://aescripts.com/path-duplicator/
Path Duplicator duplicates your layer along a path.
Автор темы - Санта
pt_ContactSheet
pt_ContactSheet
http://aescripts.com/pt_contactsheet/
Create contact sheets or storyboards out of selected frames from a precomp or footage layer.
Автор темы - Санта
pt_ContactSheet
rd: Comp Sheet
http://www.redefinery.com/ae/view.php?item=rd_CompSheet
This script displays a palette with controls for building a “contact sheet” composition based on “style frames” in the current composition. Use this script to view different frames of a composition at a glance.
Автор темы - Санта
pt_Panorama
pt_Panorama
http://aescripts.com/pt_panorama/
Converts a panoramic image into a 3D cylinder that can be used as a background in a 3D composition
Автор темы - Санта
pt_Multiplane
pt_Multiplane
http://aescripts.com/pt_multiplane/
Instantly turn layered Photoshop or Illustrator files into 3D multiplanes. It adds expressions that let you freely move layers on the z axis without changing the look of the shot from the original camera position, making it easy to experiment with depth in your scene.
Автор темы - Санта
Layer Repeater
Layer Repeater
http://aescripts.com/layer-repeater/
Easily animate offsets in space and time for multiple layers
Кажется это аналог Trapcode Echospace
http://www.youtube.com/watch?v=TiD0sSzo0xI
Автор темы - Санта
Images Wall Script
Images Wall Script
http://www.motionboutique.com/images-wall-script/
http://vimeo.com/44356859
This After Effects script distributes the contents of the selected folder on a grid. It also allows you to control the transition between cells.
