Экспорт маркеров из After Effects в Adobe Audition CC 2015
https://www.youtube.com/watch?v=Z4L7NQCJFEw
Скрипты для работы с маркерами
Автор темы - Санта
Автор темы - Санта
pt_LayerMarkers
pt_LayerMarkers
http://aescripts.com/pt_layermarkers/
Split selected layers at their layer markers, or add markers at the cut points of any layers in a comp.
Автор темы - Санта
rd: Key Markers
rd: Key Markers
http://www.redefinery.com/ae/view.php?i ... KeyMarkers
This script displays a palette with controls for identifying the location of keyframes on a layer by using layer markers.
Автор темы - Санта
AudioToMarkers
AudioToMarkers (Пост aeplug #1249)
Adds markers, splits a layer or adds a new text layer with incrementing numbers based on audio intensity.
Автор темы - Санта
Copy Paste Markers 2
http://aescripts.com/copy-paste-markers/
Allows you to copy one or more markers and paste them on any other layer. After Effects does not allow copy/pasting markers in their UI, so this script is here to help.
Автор темы - Санта
Layer Marker Batch Editor
http://aescripts.com/layer-marker-batch-editor/
Batch edit all layer marker attributes on selected layers. Also has an option to export the marker to a text file.
Автор темы - Санта
Add Edit Markers
Add Edit Markers
http://aescripts.com/add-edit-markers/
Will add Layer or Comp markers at the in and out points of the selected layers in a comp.
Автор темы - Санта
Render Frame at Markers
http://aescripts.com/render-frame-at-markers/
Render Frame at Markers (Пост aeplug #1254)
Will send to the render queue any frames that are marked by layer markers that are within the comp work area. This would be equivalent to going to a point in time in your comp and selecting "Save Frame As->File".
Автор темы - Санта
Rift
Rift
http://aescripts.com/rift/
Есть возможность двигать маркеры
This script provides methods to shift, sequence, stagger, or randomize layers properties like in and out points, keyframes, markers and more, presented in a compact UI.
Автор темы - Санта
Marker Remap
Marker Remap
https://aescripts.com/marker-remap/
Скрипт для другой цели (аналог Trigger Работа с курсором мыши и кнопками в After Effects через маркеры (выражения) +проект), но может удалять, копировать, сдвигать маркеры слоя.
Marker Remap let’s you retime compositions using layer markers in two easy steps!Видео уроки для After Effects http://www.youtube.com/AEPlug
