Скрипты для работы с маркерами
Описание скриптов на русском и попытка разложить их по функциональным разделам отдельно
Благодарил (а): 15 раз
Сообщение aeplug » 15 сен 2016 01:48
pt_LayerMarkers
Сообщение aeplug » 15 сен 2016 01:49
pt_LayerMarkers
http://aescripts.com/pt_layermarkers/
Split selected layers at their layer markers, or add markers at the cut points of any layers in a comp.
rd: Key Markers
Сообщение aeplug » 15 сен 2016 01:51
rd: Key Markers
http://www.redefinery.com/ae/view.php?i ... KeyMarkers
This script displays a palette with controls for identifying the location of keyframes on a layer by using layer markers.
Сообщение aeplug » 15 сен 2016 01:53
AudioToMarkers
AudioToMarkers (Пост aeplug #1249)
Adds markers, splits a layer or adds a new text layer with incrementing numbers based on audio intensity.
Copy Paste Markers 2
Сообщение aeplug » 15 сен 2016 01:54
http://aescripts.com/copy-paste-markers/
Allows you to copy one or more markers and paste them on any other layer. After Effects does not allow copy/pasting markers in their UI, so this script is here to help.
Layer Marker Batch Editor
Сообщение aeplug » 15 сен 2016 01:55
http://aescripts.com/layer-marker-batch-editor/
Batch edit all layer marker attributes on selected layers. Also has an option to export the marker to a text file.
Add Edit Markers
Сообщение aeplug » 15 сен 2016 01:56
Add Edit Markers
http://aescripts.com/add-edit-markers/
Will add Layer or Comp markers at the in and out points of the selected layers in a comp.
Render Frame at Markers
Сообщение aeplug » 15 сен 2016 01:59
http://aescripts.com/render-frame-at-markers/
Render Frame at Markers (Пост aeplug #1254)
Will send to the render queue any frames that are marked by layer markers that are within the comp work area. This would be equivalent to going to a point in time in your comp and selecting "Save Frame As->File".
Rift
Сообщение aeplug » 15 сен 2016 02:03
Rift
http://aescripts.com/rift/
Есть возможность двигать маркеры
This script provides methods to shift, sequence, stagger, or randomize layers properties like in and out points, keyframes, markers and more, presented in a compact UI.
Marker Remap
Сообщение aeplug » 06 окт 2018 18:21
Marker Remap
https://aescripts.com/marker-remap/
Скрипт для другой цели (аналог Trigger Работа с курсором мыши и кнопками в After Effects через маркеры (выражения) +проект), но может удалять, копировать, сдвигать маркеры слоя.
Marker Remap let’s you retime compositions using layer markers in two easy steps!
Вернуться в «Каталог скриптов»
